Could you do a "geothermal" setup in a cistern in the basement? 12 x 12 x 5 gravity fed from a spring through an inch and a half pipe?
SolarAndWood said:Could you do a "geothermal" setup in a cistern in the basement? 12 x 12 x 5 gravity fed from a spring through an inch and a half pipe?
Semipro said:Since this is spring-fed, is there an overflow from the cistern?
SolarAndWood said:The spring box is in the side of the hill and the pipe is a few few below the surface. I've never seen it ice over but there is no way it is 55 degrees. It then travels a few hundred yards within a few feet of the surface until it ends up in the cistern which is about 8' below grade.
trump said:Once you get too far below 55 or 50
benjamin said:How much does a couple hundred yards of insulated 1 1/2" pex cost? OK never mind.
If you have enough flow, you can certainly get enough heat out of water at 40 degrees.
The limiting factor is the lower working limit of the fluid (freezing) not the amount of heat available. Ground loops contain antifreeze because they routinely operate below freezing, as air to air heat pumps do.
That being said, if this is a camp and the spring is free flowing, why not pipe the water through some crude radiant tubing to keep the place from freezing? Insulating the pipe would go a long way towards keeping that water as warm as possible.
CALJREICH said:One of your earliest replies was from a man that alluded to the reality you may not have a big enough source of water to draw from and if you run out then your out of luck.
SolarAndWood said:CALJREICH said:One of your earliest replies was from a man that alluded to the reality you may not have a big enough source of water to draw from and if you run out then your out of luck.
Yep, I get that. Except that out of luck is not the end of the world and I guarantee you the source is big enough. What I need to figure out is how warm I can deliver it to the cistern and is it worth putting a big enough pipe in to get the flow I need to maintain 40 in the core of the house.
Either way, there is going to be a big stove as well as a big wood furnace in there to bring the building up to temperature as I have no intention of using the oil furnace again.
CALJREICH said:Is this for a geothermal system?
