I appreciate everyone’s time in responding to this thread, I’ll keep updated on my results.
Good luck, there is always very much discussion on draft issues just like yours. Finding the solutions and / or further troubleshooting are helpful to everyone here.I appreciate everyone’s time in responding to this thread, I’ll keep updated on my results.
That’s not an option for me right now. I was considering an auto draft fan.If it’s really that tight you might need to look into an ERV that is adjustable to intake more than it exhausts.
This is why I was considering it, but there comes a point of diminishing return where I’m installing all these bells and whistles just to have a wood burning fireplace. Seems entirely counterintuitive. I’m pretty frustrated at this whole thing, my kids are young and I’m very aware of CO2 or else I wouldn’t have posted my questions. Appreciative of all the help provided here.I would consider a draft fan only as a last resort.
It can fail. A chimney does not fail (if it stays clean). Physics is more reliable than electricity.
What happens if the power goes down?
Remember that when smoke comes in, evidently for some reason the gas flow up the flue is not enough. That also means that CO can come in. I'd want to be able to rely on the stove and its safety also (in particular) when the power is down.
Are your CO (and smoke) detectors up to date (not expired), have fresh batteries? Every floor
Not good, almost like it's a pugged cap or something in the chimney.Startup and everytime the door opens even when the fire is good and hot.
This is what appears to be happening. There are several causes and if this the case it will be a lot worse in milder (>45º) weather. Is there a radon exhaust in the basement? Have you tried opening the nearby window a inch to see if that helps?I will add negative pressure in the basement can be due air leaks in the upper floors. Hot air out creates the negative pressures down lower. Time for a home energy audit to find leaks and try another few feet of pipe.
I am not sure about the negative pressure. I quote from the first post:This is what appears to be happening. There are several causes and if this the case it will be a lot worse in milder (>45º) weather. Is there a radon exhaust in the basement? Have you tried opening the nearby window a inch to see if that helps?
Adding lenght to the chimney helps. Another small step that will help is changing out the 90º turn in the smoke pipe to an offset with 45's as mentioned in the manual.
There is a no so great review on that kit for this stove somewhere on here. Or maybe it was reddit? i forget where i read it?For the OP's stove, the manufacturer makes a fresh air intake kit: https://supremem.com/documents/manuals/NOVO_EN_OM_JUN23.pdf That would solve any under-pressure related parts of the problem, and also increase the overall heating efficiency, since the stove wouldn't suck expensive heated air (excess air, beyond what is needed for combustion) out of the house.
The energy recovery heat exchanger is also a good suggestion, if it can be set to create a slight overpressure for the whole house.
Maybe just buy the adaptor, not the whole kit?T
The air intake for an OAK needs to be at or below the firebox floor in order to avoid reverse drafting. This is most important for OAKs that directly feed the stove air intakes. Some stoves have an air gap between the two to prevent this problem and can be connected in a basement. Not sure about the Supreme.Ma
Thanks but can’t run an Air kit because installing it would put it above the air kit entrance on the stove which would make my situation worse.For the OP's stove, the manufacturer makes a fresh air intake kit: https://supremem.com/documents/manuals/NOVO_EN_OM_JUN23.pdf That would solve any under-pressure related parts of the problem, and also increase the overall heating efficiency, since the stove wouldn't suck expensive heated air (excess air, beyond what is needed for combustion) out of the house.
It would not make it worse if you currently have negative pressure where the stove sits. Since it's flexible duct, can't you always make the duct intake sit below the stove level? Worst case, dig a hole...Thanks but can’t run an Air kit because installing it would put it above the air kit entrance on the stove which would make my situation worse.
If the chimney is made from proper chimney pipe,
