Yesterday it was $4.89 a gallon her and suppliers are expecting it to continue to rise. The also are telling people we will put you on the waiting list, we are working our way down.
gg
gg
I did HVAC work for a career, mainly large steam and HW boilers and chillers. I fitted my DHW flue with a Honeywell powered damper. With a power vent heater it gets it's signal from the flame module. It helps some but I don't know if it will ever pay for it self at a wholesale cost of $40.If I were building a house with really cheap off peak rates (wish we had TOU metering here) I'd install an 80 gal electric water heater on a timer, electric boiler to heat thick slab-on-grade on a timer, or at the least, 1000 gal LP tank with electric elements to heat it at night......electric storage.
I'd say heaterman's numbers ar pretty close to what we pay here.
With all this talk about water heating, a standing pilot gas unit has efficiencies in the 50-60% range, direct fired oil (Bock) are not much better. This is what happens when you have a vertical flue right up the middle of a steel tank.....
TS
Yes electric would be much cheaper than $250 a gallon propane no doubt!! My gosh!! And I thought our propane was expensive!This is really a regional decision with different rates for all the fuels. I have had 3 different water heaters in the last 3 years. 1st was oil tankless coil boiler. Running only hot water was $1,400 a yr. Then an 80 gal electric $600 a yr. Now a 50 gal hpwh $200 a yr. This is not off peak anything. I also researched dryers, electric at .19 c kwh vs propane at $250 a gal Electric was 25 cents a load cheaper.
propane is almost 6 dollers a gallon here
http://www.eia.gov/dnav/pet/hist/LeafHandler.ashx?n=PET&s=W_EPLLPA_PRS_SMI_DPG&f=W
How are prices in your area? Michigan is back down a bit $3.359.
Minus temperatures again tonight and a wicked wind. On the upside I still haven't burned a drop of propane to heat and accelerated the payback time on the new boiler.
Sorry to hear of your propane purchase. I see quite a few empty woodpiles in our township too.I payed $2.39 a gallon today in central Wisconsin. I ran out of seasoned wood.
you made the right choice. I'd move back up in a heartbeat.25 mi north of Hayward WI neighbor was just charged 4.59 and told cash up front or no fuel. I believe the
worst pain is confined in local areas. Weather guy in Duluth MN last night said its coldest recorded winter since mid 1800s and number two overall. Now please explain just why I picked this year to move north from Chicago?
Spent last weekend ice fishing on Green Bay, guess I will never learn!I called my propane company today for the current prices. $2.19 a gallon now for a owned tank. A nickel more fore a leased tank. They think it'll go down below $1.50 a gallon this summer as usual for our area.
