We just had a new boiler installed this past couple months at work. I noticed a large bag full of some type of insulation left over that maintenance was just going to throw away. I asked what it was and was told it was Kwool and I could have the whole bag if I wanted it. Well, I took that sucker home real quick. I did a little research on here and I think I've figured that in the boiler world its called Kwool, in the wood stove world it's called Kaowool. I found the company that we got the boiler from (Cleaver Brooks 450 hp) and they had some ratings on the kwool that I have. The website stated that it is rated to 2300 degrees continuous with a 3200 degree melting point. I opened the bag when I got home and discovered 7 complete rolls of 1"x3"x25' and 1 roll of 1"x2"x12'. Fantastic and free
This is the tricky part; I'm purchasing a 6" flex liner this summer and would like to use this insulation on the liner. The problem is, I don't think I can wrap it around the liner because the terra cotta liner in the chimney is only 6"x10" inside diameter. I was thinking of slightly ovalizing it and dropping into place. What I want to know is, can I cut the Kaowool into small 1"x3" strips and just start shoving and packing them in between the liner and the chimney using a rod to push them all the way down to the blockoff plate, then cap off the top? I believe I have more than enough to do it this way. The chimney is only 13' tall. I also plan on using some of the Kwool to insulate the blockoff plate. Anybody have any opinions on doing it this way?
