My wife and I recently purchased a small farm in Wisconsin. The house is older and very drafty using Propane to heat. Very expensive. So we decided to go back to wood.
My agent told me that he covers non listed Fisher Stoves if properly installed. So I decided to research Fisher Stoves. Which led me to this site. I've been lurking here for a couple of months getting up to speed and learning that I dont know as much as I thought. Okay I have to admit I got addicted to the Fisher Brand Stoves fairly quickly. So I started searching for them on Craigs list. I ran into 2 that I ended up buying. A Grandpa Bear and a Mama Bear. Both are Back vented
The Grandpa Bear will be used in the house Approx 3,000Sqf with basement. I realize if we don't count the basement it is over kill. But oh well.
The Mama Bear will be used in the Garage. Again over kill. I wanted a Baby Bear but couldn't get one. They sell very fast in our area.
The Mama is a simple install Concrete floor chimney straight up thru roof. I plan on heat shielding both to reduce clearances. The mama is UL listed with heat shielding. The Grandpa is not listed.
Grandpa Bear 76 edition 1. It has round door channels. With the taller trees. This stove is in excellent condition. This is the one I'm most concerned about regarding the install. The rear venting poses a few issues. And the location I want to use poses some challenges. I want to corner mount it near a sliding window with a thru the wall exhaust. I have 2 options on the chimney.
Option 1 ::: 90 Deg elbow out back. 4.5 ft rise another 90 Deg elbow to Stainless chimney pipe thru wall. Another 90 Deg elbow and up thru the eave. I have approx 18ft of pipe that came with the Grandpa. So if all is used we have 22.5 Ft of vertical with 3 elbows Plus 2 feet or so of vertical pipe. Will three 90 deg ells impede exhaust flow? My reasoning behind this option is based on two things aesthetics ( I really like the look of that stove pipe coming up from the stoves) and heat gain by having the stove pipe inside for more of the run as compared to option 2.
Option 2 ::: Out the back with a 45Deg elbow Due to corner mount. Horizontal stove pipe to Stainless pipe thru wall. Then 90 deg vertical thru eve. With approx 18ft of ss pipe.
How much am I gaining by keeping the stove pipe vertical in the room versus the horizontal transition to stainless out the back.?
Then there's the next issue. The window. I plan on heat shielding for clearance issues. So what are the specs on distances to windows trim etc? I was considering using a removable shield that attaches to a permanent one that will be attached to the other corner wall. This way I can remove it in the summer and use the window.
![[Hearth.com] Grandpa Bear and Mama Bear install questions [Hearth.com] Grandpa Bear and Mama Bear install questions](https://www.hearth.com/talk/data/attachments/120/120886-47f6700fa18358b2317fe1b109fc065a.jpg?hash=eH0Bf9Hfqn)
![[Hearth.com] Grandpa Bear and Mama Bear install questions [Hearth.com] Grandpa Bear and Mama Bear install questions](https://www.hearth.com/talk/data/attachments/121/121159-8a5b7cf04c042958ca947c3472870002.jpg?hash=SheFxR1_PQ)
![[Hearth.com] Grandpa Bear and Mama Bear install questions [Hearth.com] Grandpa Bear and Mama Bear install questions](https://www.hearth.com/talk/data/attachments/121/121160-0dcd22bc4a6447af6b6187db8a772cb5.jpg?hash=XyUsVyWzFS)
![[Hearth.com] Grandpa Bear and Mama Bear install questions [Hearth.com] Grandpa Bear and Mama Bear install questions](https://www.hearth.com/talk/data/attachments/121/121161-7037c282c63a9dd440e3d7f3e780baed.jpg?hash=ctWYwgjAVU)
![[Hearth.com] Grandpa Bear and Mama Bear install questions [Hearth.com] Grandpa Bear and Mama Bear install questions](https://www.hearth.com/talk/data/attachments/121/121162-9aeb8bdb6cbbd6f5af259ba638599312.jpg?hash=jtPx6SCHky)
![[Hearth.com] Grandpa Bear and Mama Bear install questions [Hearth.com] Grandpa Bear and Mama Bear install questions](https://www.hearth.com/talk/data/attachments/121/121163-f6d0d1cdc2dfb419e560c278b27d4667.jpg?hash=EHJQ3U6PNp)
![[Hearth.com] Grandpa Bear and Mama Bear install questions [Hearth.com] Grandpa Bear and Mama Bear install questions](https://www.hearth.com/talk/data/attachments/121/121164-710f729cc52f178f734bc163c451652b.jpg?hash=tBUIrBzLTI)
![[Hearth.com] Grandpa Bear and Mama Bear install questions [Hearth.com] Grandpa Bear and Mama Bear install questions](https://www.hearth.com/talk/data/attachments/121/121298-cfbcd25f539634fa331e3fe8cb44d5ef.jpg?hash=4oqdxEYSqs)
![[Hearth.com] Grandpa Bear and Mama Bear install questions [Hearth.com] Grandpa Bear and Mama Bear install questions](https://www.hearth.com/talk/data/attachments/121/121353-42904f35bdfa5ea1f66ca20ce4ce1caa.jpg?hash=EkrV8ay3dy)
