![[Hearth.com] Grandpa bear [Hearth.com] Grandpa bear](https://www.hearth.com/talk/data/attachments/285/285401-b5fe4a4b008d718734d638370386bac7.jpg?hash=0wGj4KJl8q)
Did you buy that out of central Illinois?
He said he tried spraying something on it to clean it up on the doors but it stunk up the house. I tend to agree with you it’s been hot. I am going to brush doors down and give them a quick coat. I payed 600.00 it totalLooks nice but judging from the doors, it’s been run HOT. What’s the price?
The chimney is a 6 I put in for the papa. I will use it for the grandpa unless it’s unsafe. Should I reduce it right away to 6? Should I use a pipe dampener?It will be interesting to see what you think of the burning characteristics between the two stoves.
Does the Papa Bear have a 6 inch liner in the chimney, or are you using an oversize chimney for it that will be the correct size for the Grandpa? (Using 8 inch connector pipe for Grandpa instead of 6 for Papa?)
If chimney and vent system were correct and comparable, (6 and 8) for each stove, it would be a fair comparison. Using the same chimney you can’t compare the two.
That is a Fisher Fireplace Insert. A Mama Bear is a single door stove from the Bear Series, not the Fireplace Series that have 2 doors for fire viewing.Ok wow I have been reading everything I can find on these stoves. Wish I would have found this info when I installed my papa bear. Better late than never.
I use the stove to heat my garage mainly on weekends and cold snaps. When I installed the papa I put a 6 inch thru the roof kit in. Until last night I was planning to run 8 blk pipe to the ceiling and then adapt down to 6. If I understand this correct I should reduce it close to the stove without a pipe damper? I never knew about the baffle so I will be making one soon.
The papa was plenty big enough for my garage 28x40 attached I just really love the fishers and always wanted a papa.
I also bought a mama insert early spring and realized I can not use it. So for now I have a mama insert and a papa freestanding for sale.
View attachment 285373 View attachment 285374
The chimney is the engine that runs the stove, like the engine in a car. It should always match the stove opening for best operation. It is also against code to reduce size from the stove opening.The chimney is a 6 I put in for the papa. I will use it for the grandpa unless it’s unsafe. Should I reduce it right away to 6? Should I use a pipe dampener?
Wow that's priceyWell that would have been a steal. I gave 600 for this stove. I now know it may not be my best stove for my current setup. So it may go back up for sale. Well see I am going to burn it a few times and see how I like.
At least you have the feet that sell for up to $100 each, usually more like $300 a set for fine condition, so you will get your money back for it. Every one of mine so far is an excellent investment. Just have to find the right buyer. Prices can be all over the place when sellers don’t know what they have, or buyers read too many threads here and get desperate. I never smoked or was hooked on any drugs, but I can’t turn down a good deal on a stove I want. I’ll stop there before writing something I regret while taking these pain meds now.Well that would have been a steal. I gave 600 for this stove. I now know it may not be my best stove for my current setup. So it may go back up for sale. Well see I am going to burn it a few times and see how I like.
Welcome to 2021.Wow that's pricey
My garage is a garage but it’s built like a shop well insulated has a bath and kitchen it. It’s more like added living space/shop we tinker in there. We don’t park in it very often at all then it’s my truck (deisel) no gas storage or anything like that. I am very careful about that. My insurance company knows about my stove and come out and inspected. Going to call my agent tomorrow to double check. I didn’t know they were banned. I know I pay a premium for having it.At least you have the feet that sell for up to $100 each, usually more like $300 a set for fine condition, so you will get your money back for it. Every one of mine so far is an excellent investment. Just have to find the right buyer. Prices can be all over the place when sellers don’t know what they have, or buyers read too many threads here and get desperate. I never smoked or was hooked on any drugs, but I can’t turn down a good deal on a stove I want. I’ll stop there before writing something I regret while taking these pain meds now.
If you put a baffle in it, which you should, adjust the opening the smoke travels through to be the same square inch area as your chimney flue. At least 28.26 square inches and lower it to increase the opening if smoke wants to roll in when opening doors. Also never open doors quickly with any stove. Later Fisher models have a double acting latch that doesn’t allow the door to open quickly. You have to rotate handle one direction, open door a crack and rotate the other direction to open fully. This second or more hesitation allows a gulp of inside air up stack to increase draft speed decreasing spillage. You can force most any stove to burp back opening doors too fast.
An Insert up on blocks seems to be more of what you need heating a large area fast, and use a blower to move the hot air from around the back through the double wall inlet and exhaust across the top. They load like the Papa, easier than Grandpa being deeper. They also have a decent area at the top front for a cook top. Baffle it as well. Just stick an 8 inch reducer in the top then reduce with damper in the pipe. Use a pipe thermometer for whichever you decide to use. I test with a infrared thermometer to test stove surface temps as well as temperature drop as it rises up pipe. You won’t know what each stove is doing without it, and they’re cheap. Be most concerned about the temp where pipe enters chimney, then it’s a guess as how much cooling from there up. That depends on the type of chimney pipe and insulation. Insulated double wall (best) or insulated triple wall chimney pipe, or uninsulated masonry (worst)
If you pull vehicles into it you can't have a solid fuel burner in it. You havnt been able to for decades. I think it is a stupid rule but if anything happens unless your insurance company gave you a written waiver for the code violation they absolutely have grounds to reject the claim.My garage is a garage but it’s built like a shop well insulated has a bath and kitchen it. It’s more like added living space/shop we tinker in there. We don’t park in it very often at all then it’s my truck (deisel) no gas storage or anything like that. I am very careful about that. My insurance company knows about my stove and come out and inspected. Going to call my agent tomorrow to double check. I didn’t know they were banned. I know I pay a premium for having it.
The grandpa was a sentimental purchase. I wanted one when I bought this place but all I could find was a papa. It has served me very well.
I put the Selkirk double wall 6 insulated kit in it was inspected after install. No problems. I take my inside pipe down several times a winter and clean it. I get nervous about a flue fire.
From what I have learned in last two days I was burning my stove all wrong. I will be changing that.
I plan to keep grandpa and install a baffle. Unless insurance just throws a fit. I don’t think they will they know how I use it.
I appreciate all the feedback.
I have 2 sets of feet now. The set I just got I think are really nice. I hear the grandpa screen is pretty rare and desirable. So I think I can make my money back if needed.
There are several on marketplace and one on eBay for crazy money 1000 and up.
I called my agent and asked if straight up if I am covered with my wood stove in my garage. He said yes my insurance company is aware of it and I am fully covered. My company is foremost. That’s all I know. I told him of our forum talk here.If you pull vehicles into it you can't have a solid fuel burner in it. You havnt been able to for decades. I think it is a stupid rule but if anything happens unless your insurance company gave you a written waiver for the code violation they absolutely have grounds to reject the claim.
I personally choose to take that risk in one of my garages but not in ones associated with the business. It's up to you whether the risk is worth it to you.
Ask him to show it to you in the policy. He is a salesman when it comes to claims he has nothing to do with it. Some insurance companies will just pay the claim. But it's a riskI called my agent and asked if straight up if I am covered with my wood stove in my garage. He said yes my insurance company is aware of it and I am fully covered. My company is foremost. That’s all I know. I told him of our forum talk here.
I ran a small fire in the grandpa last worked well with the exception of whatever he sprayed on it to attempt to clean it.
Got my metal for my baffle plan to cut it in the next couple days and fit it.
I’m not planning to run stove in fireplace mode so I might sell the screen. What should I ask for it?
Thank you all for the vast knowledge.
He sent me my policy where it states that I have a wood stove in the garage. I understand the risk. I don’t do anything risky in there when stove is on.Ask him to show it to you in the policy. He is a salesman when it comes to claims he has nothing to do with it. Some insurance companies will just pay the claim. But it's a risk
Please don't take this the wrong way I am not being combative towards you at all just trying to make sure you have your bases covered. And you a don't have to argue the code with me. I agree completely it is stupid. Does the policy say that the woodstove and any resulting damage is covered dispute the code violation? And are there any other sections excluding coverage on willful violations.He sent me my policy where it states that I have a wood stove in the garage. I understand the risk. I don’t do anything risky in there when stove is on.
I can see why it’s against code.
If you sell your grandpa screen, I would be interested in it.I called my agent and asked if straight up if I am covered with my wood stove in my garage. He said yes my insurance company is aware of it and I am fully covered. My company is foremost. That’s all I know. I told him of our forum talk here.
