Good morning! I’m green as green can get! I’m interested in putting a small wood stove in my 1200sf house. My living room doesn’t have a “good” spot for one but my dining room which is open to the living and kitchen does. I’m thinking about one in a corner. I was looking at possibly a Jotul Black bear. Besides the $2200 just for the stove sticker shock I’m also concerned about warping and cracking. So, maybe steel stove? Also, do I need a stove that big. It’s rated to heat 1400 sqft. The back of the house is just bedrooms and I can’t see the heat making it that far without roasting the rooms the stove is in first. So, what brand names in steel stoves should I consider looking into and Possibly a recommended size. Thanks.
Yes, steel stoves are usually found to be more durable than cast stoves, not because of steel vs. iron, but because of welds vs. cement and gaskets. However, either one operated within its directions and limits should give you ~20 years of reliable performance. You should never have issues with warping a stove unless you have failed to maintain the gaskets or are operating it in a way that violates the instructions.
1200 s.f. is a relatively small space, which usually means going one of two routes:
1. A smaller non-cat stove, which will have a comparatively short burn time due to the small size of the fuel tank.
2. A medium cat stove, which will usually cost more, but can give you a much longer burn time.
The issue here is that all modern (EPA) wood stoves work best in a batch-burning mode. This means that, unlike a fireplace or antique stove where you may just chuck a few sticks into it every 2 hours, any EPA wood stove works best when loaded full and set for a given burn period. This is because they rely on getting a secondary burn system (the aforementioned “cat” or “non-cat” system) up to operating temperature, which extracts far more heat from the wood than the older tech.
The reason you can go bigger on a cat stove is that they can usually be turned down to a much lower burn rate than a non-cat, because the catalyst can support the secondary burn system operation at a lower temperature (500F vs. 1100F for non-cat).
Because you mention you’re price sensitive, I’d be looking at the smaller NC from Englander. I believe Drolet also has a smaller (1.7’ish cu.ft.) stove that gets solid reviews. If looking at medium cat stoves, you’d be in the “20” series from BK, or the Fireview from Woodstock, but these are substantially more than the $$ that gave you sticker shock in your OP.
You’re going to be in the < 2 cu.ft. non-cats or > 2 cu.ft. cat stove territory. Figure maybe 6 hours burn time from these small non-cats, or roughly double that from a medium cat stove, as your likely sweet spot in that size space.
