I have a Greenwood model 200.  Sometimes the aquastat does not trigger the damper motor to open the damper.  I have replaced it and the problem persists.  I thought I got a bad aquastat and the company replaced it. I can manually trip it by rotating the dial down and back up and it works.  It is set to 180 deg.  with a 15 deg difference.  When I turn it down past the current water temp and back up it will trigger the damper motor. Example: Water temp drops to 150 and does not trigger the damper, I rotate aquastat down to 140.  As it passes 150 it clicks.  When I rotate it back to 180 it will trip the damper at or around 150, the current water temp.  Any ideas?
