Finally bought the generator. Took a few more months before I assembled it. Got the propane tank and was considering adding the oil and firing it up when I got confused on the manual's caution on grounding.the unit.
Sounds like it reads that they've connected the frame to ground terminals in the AC receptacles and the unit can be used as a portable without grounding the frame.
However, it talks about grounding the unit in a building stand-by application with #10 AWG stranded Cu wire to an earth-driven grounding rod.
So if I want to start this thing, run it for 30 minutes to drop and replace the engine oil, I don't have to ground it?
BTW, I won't understand any explanations I get, but I will follow instructions! Maybe this thread goes in DIY, but I got it to run the blowers on the wood stoves among other things.
In the bars, you never know what you're going to run into.
