My one year old absolute 43 started feeding too many pellets and would fill the ash pan in 1 1/2 days with partially burned pellets. Easy fix right? Turn down the feed limit, right? Nope! Did the same thing the next day 25%(lowest feed rate). So I gave the stove a good cleaning and I have the dealer coming out to give it its first pro clean. I am not sure if it works because now it says "Warning:door open" and the pressure switch wont close so the stove will not ignite. I obviously have the doors closed and the rope seals appear to be in good shape so I am not sure what to do to fix this. The dealer is coming Tuesday but it's going to be a cold couple of nights if I can't get this fired up. Please help** Thank you
We have a winner! The stove I had for 10 years before this one did not have a screen on the exhaust vent and I did not know this one had one. Sure enough, a quick peak out side and there is a screen and it is solid. I take it out, clean it a little, go back in-stove fire right up. This obviously fixed both problems I was having.
Glad to hear you found the solution...
