Hello!
I am new here and need help with a problem. A couple weeks ago my Harman Accentra 52i insert stove started getting a 6 blink status light. For a few days, I just reset (by turning off, then on) and it would continue to burn for about an hour before it got that same error. I did some research online, and found a few things that might cause this. I replaced my rope gasket on the door, which definitely needed replacing. After that, it burned fine for about 12 hours, then the problem returned. Then I replaced the ESP. It burned fine for over 48 hours, then the problem returned. Somewhere in there, I cleaned out the fines trap, tapped out anything that would fall out of my 4" flexible exhaust pipe which goes to the top of my 2 story chimney, and cleaned the heck out of everything I could. I usually use the standard Tractor Supply pellets, nothing special. I tried Lowe's premium pellets for 4 bags without any difference.
I burn my stove on 'stove temp' and never on 'room temp'. I don't even have a thermostat hooked up. I typically run the feed on 3-4. This is the 4th season that we've had our Harman and it is the primary heat source in my house. I called the dealer where we bought it and just about fell over when they told me how much a service call would cost, plus parts. I'm not sure if there is anything else I can do, short of the control board.
Any help would be appreciated. Thank you!
