I have a 2006 Accentra and wonder when it would be time to replace the door gasket.
There isnt any smoke leak or sealing issue yet, but because it is a full length door, the gasket at the bottom end of the door seems to be getting a lot more crushed and deteriorated because ash settles at the stove bottom.
I remember when the stove was new, you could open the door and little ash would fall out because the gasket was big and plump and manually sealed better.
Am I heading for a stove pressure issue if this gasket doesn't seal well- because it only has gotten cruddier a little bit at a time..over many years.
Did not know if there was a way to judge a fiberglass gasket for being flattened out. I only know it would be bad if it was outright broken/ frayed.
I notice that with the tiny door stoves like the P43 and the P38, maintenance seems so much simpler.
