Harman Accentra Insert combustion blower Wiring??
Worble7
59
Fremont, Ca
So I bought a new combustion blower (2006 Harman Accentra Insert) and just want to make sure I wire it right?? No directions in the box I guess there more I bought it off Ebay from Mr. Pellethead So I will post pics of the way I think its supposed to be wired. Please make any corrections that are needed. Thanks Jeff
[Hearth.com] Harman Accentra Insert combustion blower Wiring??
No one knows where the wires are supposed to be? I'm sure someone knows :) Thanks
green is your ground attach to housing. the other 2 does not matter
Reactions: heat seeker
Is this the blower on the bottom of the unit or is that a distribution blower? I'm considering replacing mine also, as I've heard some squealing at start up. How difficult was the replacement for you?
I started a post. I'm wondering if a faulty combustion or distribution blower would prevent the auger from turning. I replaced the auger motor last weekend, but still having issues.
Should not make a difference. At the worse case the blower would turn backwards, just switch the two power wires.
