I bought the extension kit with my linteater so I can reach to the top of the liner from inside the house.
			I'm a little shocked it ran pretty well for 3 years without a vent cleaning as well!?!Well guys, I think it have solved my problem. I bought the brush kit and ran it 12 feet up the chimney, a healthy pile of soot poured out. I may need to either buy a few more extensions or get on the roof and hit it from the top.
Next up, the distribution fan. Believe me when I say this, I'm shocked this stove ran at all considering the amount of dirt and lint and anything you can think of, that were clogging the fan blades. I tip my hat to a Harman for making a stove that can still put out some heat even when it's filthy!!
I have her cranked up to 75 on room temp, and it's only been on for an hour and it's almost reached temp!!
This thing is cranking now! It even sounds better!!
I am hoping, (and I'm sure I have) got this thing back to a much needed efficiency!! I went to a cleaning class when I first bought it and I'm a little disappointed because they never mentioned the exhaust, or the fan, in the class. Thanks to all of you guys and gals on this forum I can sleep now! Lol
Yes, you need to clean in there too. I use a crevice hose for my vacuum being careful not to damage the ESP. http://www.amazon.com/Loveless-Ash-Vacuum-Cleaner-Pellets/dp/B000SSPH5C You also need to gently brush/wipe off the ESP. Everywhere that needs to be clean is listed in the following link. (broken link removed to http://www.harmanstoves.com/Owner-Resources/~/media/Files/Site%20Downloads/HAR/CleaningInstructions/AccentraInsertCleaningInstructions.ashx)Before I get to excited, are there any more areas that need to be cleaned that I might be unaware of? I think I hit them all now.
How about the inside where the esp probe is? I notice there's two wing nuts on the side where the probe is. Is that something I should be looking at?
I have had a harman accentra insert for three seasons now and absolutely love it. I keep the setting on auto with a room temp around 70 degrees. I have had no issues with it so far. My question is with the bitter cold were having here in New England is it normal for me to crank the stove temp up to 80 degrees to maintain the house at 70? If I leave the dial set for 70 I notice the house temp drops down to 65 or so. I have about 25 bags in since last cleaning. I'm just curious if this is normal due the extreme cold. Like I said earlier, I have the stove set at 70 and it has maintained 70 just like clockwork until this week. Any input would be greatly appreciated!
I would assume that if I crank it up to the maximum output it would feel like an oven in the house, but I'm not so sure if it will get much warmer than 70.
The stove is hearing a 1600 square foot ranch.
I will crank it up to about 80 degrees to achieve a room temp around 70. It is going to be another cold night here in New England.
I do not have a thermostat wire on the stove, I just have the esp probe controlling the temp.
Also, should I be cleaning the exhaust
Port that goes into the chimney? I haven't read anything about that yet, I have mainly been cleaning the stove itself, which I do a very thorough job of.
Thanks guys for your input so far!!
Justin that was a amazing thread on cleaning the accentra . You wouldn't happen to have one like that in the p35i would yaYes, you need to clean in there too. I use a crevice hose for my vacuum being careful not to damage the ESP. http://www.amazon.com/Loveless-Ash-Vacuum-Cleaner-Pellets/dp/B000SSPH5C You also need to gently brush/wipe off the ESP. Everywhere that needs to be clean is listed in the following link. (broken link removed to http://www.harmanstoves.com/Owner-Resources/~/media/Files/Site%20Downloads/HAR/CleaningInstructions/AccentraInsertCleaningInstructions.ashx)
Sorry, just the ones that are listed in the link in my sig.Justin that was a amazing thread on cleaning the accentra . You wouldn't happen to have one like that in the p35i would ya
Roll another one, nice jobGlad she's runnig goodI hit the 25ft fiberglass rods that screw together and the 4 inch brush.Havnt don't my ton cleaning on my harman yet but I'm all ready.
