Harman accentra shutdown
curtb01364
6
Massachusetts
Have had a used Accenttra for few years,been a nice stove.One thing has me curious,when I shut stove down the distribution motor shut right down,would think it would run till the "hot" stove cooled down,what does other accentra users find out?Manual really doe not indicate whether it should or not in shut down procedure
Mine does the same. The distribution blower will continue to run only if the stove is very hot.
Reactions: curtb01364
My guess is that the stove is designed to turn off distribution motor(s) so less heat is distributed into the room occupied by the "shut-downer person" pushing the off buttons?
Reactions: Ssyko
If it is gets to warm it will kick it back on.
Reactions: Ssyko
My Accentra distribution blower runs at a very low speed during shut down, if you put your hand near the area where the hot air comes out you will feel the movement of hot air, not enough to heat the room but just enough to help cool the unit down.
Thanks for reply,have noticed on few other stoves,non Harmans that the distribution motor would continue to run till stove cooled...kinda thought that was a good idea rather than just letting a hot stove cool down on its own,was just curious and at times if it is running hot I will lower feed rate for a bit before shutting down
Reactions: Ssyko
My room blower runs a short time during shut down..which I assume is controlled by the ESP..
