just picked up the newest style...got to take some pictures So different from anything I have seen..Pictures will be posted within the hour. I am very impressed
!No the floor does not come out...as for the slits...your guess is as good as mine...my guess is the slits are for contraction (cooling off) Could be bothHoly holes! I'm assuming the floor is designed to be removed for easier cleaning? The slits are for expansion?
I have the newer pressure igniter so I don't need to do anything. If you have the older finned igniter there is a list of dipswitch settings I almost never let it idle as it lights so quickly. It has a lot of holes!Just noticed from your sig, it's for your PB 105. Never opened one up and looked inside, nor do I know much about it. What is the idle burn like? Gotta assume it's very low. Maybe the additional holes improve the stoves "throttle response"? Do you have to re-flash the board for the new burnpot? So confused. I don't know what I'm looking at...but I like it![]()
does yours have the holes on the side?I got a new burnpot under warranty this summer. Mine has the floor welded in, though, and no slits, similar to the one Centurion showed in this thread last February. Perhaps they're "field-testing" several designs, since warpage has proven to be a headache for them.
did it look like mine?Put in a new style burnpot today. On the box it said 309 stainless. It should be good for around 1800 degrees. Time will tell.
just picked up the newest style...got to take some pictures So different from anything I have seen..Pictures will be posted within the hour. I am very impressed!
