What's your GOTO? Currently I use the stock supplied tool and a long screwdriver, but am looking for better. Am considering some chisels and punch but would like others opinions!
Harman tool for daily scraping, mechanics pry bar for cleaning.
(broken image removed)
It's about 5/8" and the bar is long enough that I can put my other hand on it and push down for more down pressure. It works very well. The Haman tool is too flimsy to put enough down pressure on it when doing a full cleaning and chipping off the "speed bump".How wide a head?
The Harman tool won't touch the bump well or glaze if you get any. I use a straight blade screw driver for that. For scraping under the fire I use the Harman tool though.Pick up a Harbor Freight wood chisel about 1". Stick it straight down and twist. Works like a champ. Then use it to scrape too. You can even grind one side to a sharp edge. Little investment. Great tool.
Gasket scraper.....craftsman is what I have but really any gasket scraper should work fine. Works Way better than the stock tool.
