Harman Invincible Insert Mid 90's
Checked all the outlets in the house and all read at roughly 125 volts. Ordering a new esp probe tonight. All DIP switches are off right now. Stove operates normally except for the auger running constantly when turned on. Haven't actually lit a fire yet because all it does it push pellets out of the pot. Would removing the feeder micro-switch fix the auger running constantly? I appreciate any and all help you guys can give me because I'm up a creek without a paddle and winter is coming.
We only replaced the board and a new wire harness because it melted. Replaced all wires one by one to ensure proper placement. Did you remove the micro-switch??
There is one wire that went no where because there no place for it when I put in new board. I don't know if that was micro-switch i think it was the feeder switch. [Hearth.com] Harman Invincible Insert Mid 90's
Replaced esp probe and removed micro switch from feeder body. Auger is still running constantly and the feeder light on the board has not come since replacing the board?
