I was going over a enviro fire pellet manual this morning, and they also "Strongly Recommend" OAK. I really enjoyed Mike's post. Thank you.
tinkabranc said:Hmmm...sounds to me like this type of revision to the manuals where an OAK
is now "strongly recommended" and/or "required" could create a loophole for HHT to
get out of some warranty issues.
..."well sir, you are SOL now on your issue because you do not have an OAK installed
on your stove and the new manual states it is required."...
This may not be their intent of course, but I work with contract provisions every day and
this was my first thought.
watrskir said:quoted from stoveguy...."i'd be remiss if i didnt mention that a well maintained frequently cleaned unit is less likely still to suffer this malady (gasket maintenance folks!)"
Sorry I probably should have started a new thread on this but what is required for gasket maintanance on a stove besides vacuuming of the ashes
still havent figure out how to properly quote someones comments
watrskir said:unless my older manual doesnt say that.......hmm where did I put it??
watrskir said:From my earlier post, does anyone use an OAK up their chimney for an insert? I'll ask the same question over on iburncorn.
flashbang said:From the manual:
"The outside air connection will supply the demands of the pellet appliance, but consideration must be given to the total house demand. House demand may consume some air needed for the stove, especially
during a power failure. It may be necessary to add additional ventilation to the space in which the pellet appliance is located. Consult with your local
HVAC professional to determine the ventilation demands for your house."
WTF is this all about?
Put a pipe to the outside for combustion air, but that may not be enough?
The Lifetime warrenty is a joke, actually it is the best joke in the industry.
poooooooooooooooooooooooooooooooook said:whats a ballpark cfm range for a 25pdvc? how much air being blown out straight out the wall with no chimnistoveguy2esw said:flashbang said:From the manual:
in some cases during a power outage while the stove is running (even with the OAK) other devices like i mentioned in the post earlier could already have the house in a negative pressure state. now , if the stove and venting system is completely airtight there is little chance of smoke release in the home, however if the unit has an "indirect" intake connection (i have seen stoves with a pipe to attach the OAK to that is not sealed on the inside to the combustion chamber, which could allow smoke spillage in the event of power failure) non sealed hoppers as well could be a source of smoke spillage which could result in a major issue such as a burnback/smokeback. stoves with some use on them which may be ready for new gaskets could also fall into this category. notice that the manual didnt state "you must" but that "it may be necessary" the purpose of this is twofold, first of all , no manufacturer wants a customer to have smoke spillage in any event, and also to protect the manufacturer in the letigious society we live in today. either way , its a reasonable statement to have included in an instructional manual.
tonyd said:Medreach, Please don't tell me the two holes are way better then one. I have a stainless cap up top and I ruined everything in my shop that had anything to do with drilling or cutting that 2/1/8 hole for the pvc pipe. It was the ONLY problem I had. EPA strongly recommenced that I re-burn the exhaust gasses. Now my stove won't have any problem passing emissions. EGR he he. Let me know how it works out.
Mark Fellows said:You know, I'm just not going to worry about it. In my parents house we burned wood for a large portion of my life. Mom would often forget to open the damper and smoke would back up into the house. My house isn't that tight, I have a 5 foot vertical run making draft in a power outage, and it's got a combustion fan. OAK doesn't prevent an exhaust leak and that is the only place in the stove where I could get positive pressure if the combustion fan goes out.
As for the warranty, I am just not going to worry about it and assume I am grandfathered in until there is a problem, and then if they don't cover me, I will raise all sorts of hell!
tjnamtiw said:Gio said:Just because a pellet stove appears to run fine without a OAK doesn`t necessarily mean it doesn`t need one.
The benefits might not always be obvious by looking at the flame.
Why go through all the the trouble and expense of installing a pellet stove and omit this rather simple , low cost part of it.
Not to be a poo poo'r, but adding an OAK is NOT a 'rather simple, low cost part of it'... For instance, the OP has to cut through brick, studs, and his outside wall to add one. In my case, one of my fireplaces is on an inside wall with no access at all to outside air except to run an extra 17 foot long flexible pipe up my chinmey and out along side of the exhaust pipe. No where in the Quad literature does it say how long this OAK line can be without restricting the ability of the combustion blower to acheive proper flow. I'd love to do it, but I just don't know how in my case.
My other stove insert has an ash dump plate in the floor of the fireplace so I could go out there. These stoves also take in room air through the hopper since it isn't sealed. I assume there is no seal so that airflow goes into the firebox rather than very hot air filtering back up into the pellets in the hopper.
