Took advantage of the rainy day to do a little Summer Cleaning of the stove and pulled the back off the Oakwood. This "downdraft" stove has the fragile "afterburner" package that burns the smoke in the lower back of the stove, as opposed to the usual burn-tube stoves that do the secondary burn up top. Similar technology is used in the Lopi Leyden and VC Everburn models (VC pioneered this system, but their stoves seem to have the most problems with it).
With the back removed I can carefully pull the combustion package straight back and out. It was loaded with very fine ash, a few cups worth, after one season burning. Some of you may remember Dill's post last fall about his Harman's smoke problem, which turned out to be ash buildup over several seasons. So I guess I'll be pulling the stove all the way out of the fireplace to do this every year.
The actual ceramic fiber piece was in okay but not great shape. This was a brand new part at the start of the season. When I bought the stove last summer, at one year old, the piece was burnt through, broken and crumbly. The owner had overfired. I didn't burn that hot, but even so, the replaced part now shows some cracking and is very brittle, and slightly charred on the back face. I'm almost afraid to take a vacuum to it, though I'm sure the many tiny holes in it have plenty of ash stuck in there. I'm handling it a lot more gingerly then when it was new - I expect this $300 part will last 2 or 3 years more at best, kind of a bummer. I avoided a cat stove to escape some maintenance, but now I'd just as soon have a cat to clean and replace.
The catch-22 with these stoves is they need to be run hot to engage the afterburner, but the afterburner isn't made of material that takes that well to the stove being run hot. (Hey, at least I can grill a great steak on the thing!) An excellent stove, solid and beautiful to look at, heated the whole house with much less wood than expected, so I hate to complain about it. Except for the fact that I like to complain. But really big thanks to everyone on this forum who taught me to burn dry wood (including pine!) - this stove would have been a complete disaster if I had tried burning the stuff I had been burning the past few years.
Something else that other Harman owners might want to peek at: when pulling the back, I noticed a bolt holding the damper assembly was loose. I checked the others and all four (TWO OUTSIDE, TWO INSIDE THE STOVE) were very loose. I had noticed a little jiggling of the damper during the season. I guess I hadn't noticed a little jiggling had turned into a lot, as opening and closing the damper repeatedly had loosened all the bolts - I almost jiggled the damn damper right off. Something to keep an eye on...
