Hi Don. Sounds like you are not getting secondary burn much at all, or the back would be getting hot. The CP could be clogged with ash, which cannot easily be cleaned without removal (I agree, do not bother with your dealer, he doesn't sound like he knows the stove). It could also be your wood (add in some smaller, drier pallet wood to the mix) or it could be your draft if the pipe is not clean... keep an eye on that, since your burn is not clean without secondaries.
You remove the CP straight out from the back, after removing the small bolts (w/ an allen wrench) that hold the back cover on. The CP just rests there but may stick to the inside bricks or may stick to the outside cover, which is kind of heavy, so you have to be sure to pull that cover straight out very evenly to avoid damage (yes, very easy to damage)... at a few years of use, and the CP may easily crack. I no longer suggest vacuuming or removing unless really needed, as it can weaken and pull apart the CP itself, but try simply removing all LOOSE ash in and around the CP once it is removed. Mine had major ash buildup at one point in the area of the secondary air intakes.
I would try contacting Harman directly about those those little gaskets, and insist they or your dealer make good on them, since he was in error. I cannot say how big a factor they might be in your problems, but there's no reason not to have them in. Good luck!
Thanks. I'll check that. I get a good draft when the by-pass damper is open, but it doesn't seem to pull air through the CP as well as it used to with the damper closed. Lately, I have had to open the air control on the front almost fully to the right to get a good hot burn.
If I remove the bricks at the back of the stove and remove the shoe brick, wouldn't that assure that the CP won't stick to the bricks and pull apart when I remove the back cover? The ones except for the shoe brick seem loose and I have always been able to slightly move them, since they are not made to fit snugly together.
I'll have to remove the optional heat shield from the back to get at the back cover. I assume the allen-head bolts you mentioned are under the shield, and you DON'T mean the six 7/16" nuts on the studs that hold the main back part of the stove together. I wonder if the CP might also stick to the bottom of the stove and pull apart when I attempt to pull the back cover.
Another thing I noticed last year, my grate has warped, so that it arches up about a half-inch in the middle. This makes it more difficult to rake all the ashes through the grate into the ash pan. I don't remember ever over-firing the stove, but first noticed the warp about the middle of last year's heating season. When the guy from the dealer checked the stove in the spring he said no need to order a new one, since that warp wouldn't hurt anything. I wonder if that is a common problem with those stoves. According to the owner's manual, grate replacement is the one part not covered by the warranty.
The only time I may have approached over-firing happened early the first season I used the stove. It got hot enough that I could see a faint red glow from the exterior side of the rear casting on the stove that contains the fire dome, visible only when I turned the lights off. Not sure if that is normal, but I immediately reduced the draft and let it cool down, and didn't see any apparent damage anywhere.
So far, no cracks in any of the bricks. The guy from the dealer said that if a crack appears, not to be concerned as long as the two pieces will remain securely in place, but I notice some people who have had cracks say they glued theirs back together using stove cement.
Again, thanks for the info.
Don
