Harman P38+ acrid odor
gutlo
Burning Hunk
200
eastern connecticut
Got a Harman P38+ around 7 years old. Emits an acrid odor from the region of the door. Put a new 3/8" gasket on, still emits odor, maybe a little less. Put my nose right on the holes where the hot air comes out, don't smell it. Lift my head slightly higher, the odor appears.
Could it be smoke getting through the new gasket? Should I try a 1/2" gasket?
BTW, the smoke isn't visible.
I appreciate all ideas.
Check your vent pipe at startup to see if there is any visible smoke.I had a similar problem with my P68 until I found the leak.It doesn't take much to give you that smell.
Harmanizer,
Is there a reason for checking the vent pipe at startup? How do I check, especially if it isn't visible.
Thanks for the help.
If there is a leak you will see a small amount of smoke at startup.It helps if the room is dark and you use a flashlight.Are all the pipe connections sealed with silicone?The stove will not leak smoke through the stove gasket because the burn chamber has negative air pressure.The vent pipe has positive pressure and will leak if not sealed properly.Good luck.
