Hi all - I've enjoyed reading this forum for years but just recently joined. I have owned a Harman P38 for the last 7 years and it has provided reliable heat. We like the convenience and it has needed very little maintenance even though it is about 20 years old.
However after a few years of operation we are getting tired of a) the noise, and b) the smoky basement. I have attempted to fix these issues every year but no success.
The main noise culprit is blower fan. I've disassembled, cleaned, and lubed but it made no difference that I could hear. Stove is in TV room and the constant whirring is bothersome.
Smoke - the basement often gets a smoky smell, maybe due to a lazy burn? Cleaning sometimes makes a difference and sometimes not. I've sealed every crack I can find around the nipple and basement wall/rim joist but it still happens fairly regularly. No luck finding it with a flashlight either.
Interested to hear your thoughts if I keep on troubleshooting or look at replacing. From what I've read here I may not be able to fix the noise issue. And I really have no idea what to do with the smoky smell. Are the new stoves advertised as 'noiseless' or 'very quiet' able to produce as much heat as this one?
Thanks in advance for your thoughts. We really do like the wood heat (it's secondary heat to our gas furnace) but we are using it less now due to the issues here.y
Cheers
Cheers
If you go with new, you could replace the bearings on the original for a back-up...
