I have a Harman P61, 7 years old.
I have ensured all ducts are clear and clean using a brush and blowing them out. I have also removed all pellets from the hopper, vacuumed out the hopper and slide plate, no debris, and I blew it out and put fresh pellets.
All wires are connected and in good shape.
Ignition wires in burn pot are good.
Fuse is good.
Pressure switch hose is good and no holes.
Doors are confirmed closed when trying to operate.
When I run test the combustion fan operates properly.
Issue started at first it would feed as it normally would, then auto ignition and light, but then stopped feeding and went out, 6 blinks.
Then I tried again and this time it did the same thing.
The third no pellets would feed and no auger movement, 5 blinks.
The issue seems to be the auger, a Gleason Avery #3-20-60906.
I did notice that there is some leakage on the auger, very little on the floor, but some leakage around the seals of the auger and some blow back grease on the backsplash below the diagram on the inside panel.
Thoughts?
Thanks,
Brian
Fuse is good.
Thoughts?
Thanks,
Brian
![[Hearth.com] Harman P61 Auger [Hearth.com] Harman P61 Auger](https://www.hearth.com/talk/data/attachments/310/310292-f9514032589b0468e2e184f0870de1c9.jpg?hash=DcMX5d-GPL)
![[Hearth.com] Harman P61 Auger [Hearth.com] Harman P61 Auger](https://www.hearth.com/talk/data/attachments/310/310986-712c9d2969db9dfc9fba7d0259d3b231.jpg?hash=Pi188B6esi)
