Hi All,
I seem to be having a problem that hopefully I can get some suggestions on. I have a 5yr old Harman P61A. The force of the heat coming out of the front is not nearly as strong as it used to be. The last 2 or 3 seasons, I noticed that the variable speed dial is acting funny. It goes from low to high but hesitates a second on high then I have to twist it a little and it will stay high. This season the high doesn't seem to be high at all now. I can stand 5-6ft in front of it and barely feel anything coming out. Before it used to move the plants 15 or so feet away. I don't know if I should look at the motor or circuit board first. I do clean the stove often so I don't think it's a cleaning issue. Last season I had the shop where I bought it come in and clean it. He cleaned it and also plugged a probe into the circuit board and checked the voltages and whatever else they check and everything seemed ok. To him, everything was operating ok. Sorry for the long and confusing post. I plan on call my stove shop back to come out and fix it but I was curious if anyone saw this problem before.
thanks
thanks
