I have a newer version P68 pellet stove, which has the 6 rpm feedmotor. It stopped running. I took the feedmotor out to check if the auger was stuck. The auger rotates fine without any resistance. I then ran the feedmotor disconnected from the auger in test mode, red feed motor LED is on, all covers are closed. I can hear the motor humming, but it does not run. I measured the RMS voltage on the cables and there is 118V. My initial conclusion was that the reduction gear had failed and offered too much resistance to the motor, but then I connected the motor directly to a 110 outlet via a cable I put together, and it runs fine. Soooo....now I can only think of 1 thing: since the 110V is present, the power supply cannot deliver the current to run the motor. I noticed there is a 6 amp fuse on the control board, but if that would have failed, none of the other motors would run, right? The other motors supplying airflow through the burn chamber and distributing air into the living room run fine. Have you seen this before? What is the fix?
I also noticed there is a slide plate above the Auger at the bottom of the hopper, activated by a lever on the feedmotor assy. I remember looking straight at the auger though on previous occasions when I was filling an empty hopper. How does this slide plate work, why is it there?
