Harman P68 intermittent distribution blower
dantm
8
Maine
I have a Hartman P68 where the distribution blower occasionally does not come on when starting. At other times it has gone off unexpectedly while the pellet stove is running.
There are no error codes from what I see. Today I opened the back and took out blower, tested it before cleaning it and it ran fine on outlet power connected directly. Then cleaned it, put it back in and it worked again eventually.
What is the next step in the debug?
Next time it acts up,gently tap, or/and turn the control knobs a little bit. See if things change.
Yes,your problem is classic of dirty or going bad pots. Clean them with contact cleaner. Also are easily replaced.
Reactions: jackman
Where do you set your pot for room temp?
What are the pontiometers to get for the P68 is there a reference somewhere? I need the PNs and they can be probably found at Digikey or Mouser?
And the other pot is at full on the room temp pot?
Yes, either 'H' or 'L' which are the two settings for ROOM TEMP pot will not turn on the blower. But it's intermittent and I haven't been able to see a pattern.
Earlier it looked like moving the speed pot from ROOM TEMP to OVEN TEMP and trying randomly H and L on both eventually kicked it in...
Reactions: Washed-Up
Best Pot cleaner I've ever found (no, not firepot) is CRC MAF cleaner. You can get it at any auto parts store. Good stuff. I use it on my ancient AM-FM radio when the pot's get scratchy. Use it on the cars too.
