- Sep 26, 2013
- 8
I have a Harman P68 Pellet stove that will not ignite and is not acting right. It acts like their is heat all of the time; when you plug it in even in the off position the combustion blower will come on even when the unit is cold. I replace the ESP sensor in the exhaust thinking that was the problem but it is still doing it. The ignitor light never comes on even though it is set to off. We also replaced the room temp sensor as well as the combustion blower which was bad. The ignitor tests fine... I am reading around 50ohms on the multimeter and when I apply power directly it does heat up. Should I be looking at a new control board? I am not sure how to test the auto/manual switch (not sure what is suppose to be open/closed in different positions). Any help would be greatly appreciated.
