Harman p68 ringing noise
Bespin
4
Enfield ct
Hello,
I'm hoping someone can help me with an issue I'm having with my Harman p68. I purchased the stove new in 2022, so I'm going into my third season of use. I absolutely love the stove and it's performance. However, I can't lower the distribution blower without the stove making a rather high pitch ringing sound. It doesn't make the sound when the blower is in the highest position, and it still occurs even when I give it a good cleaning. It's really quite irritating and it would be nice to be able to lower the stove so it's not running wide open constantly, and to make it more enjoyable to sit near and enjoy something I spent about 8 years desiring to obtain, not to mention the cost of the stove. I provided a link to a video that I uploaded to YouTube so it can be seen what exactly I'm trying to describe. Really hoping someone can help.
motor will probably need replaced
Reactions: Ssyko and ARC
Try a few drops of 3in1 oil on the bearing caps
Reactions: johneh
it's not a bearing sound
the motor is made to run at 120 volts and when you lower the speed with the potentiometer you lower the voltage so the motor does not run at 120 volts but a lower voltage.
The sound comes from the wire winding in the motor
Well if you’re positive on the diagnosis then a new motor is in order. Just saw that you’re in PQ…great memories for me when I lived there for a couple years…keep us posted
Thanks for replying. So is this a defect in the way my motor was wound? Or is this how the p68 distribution blower sounds when lowered? Does your stove do this as well? Cause for the price of the stove it should have been engineered better.
even with a new engine it can do the same thing it depends on the manufacturing quality of the engine.
Washed up we can get out of Quebec but we can't get Quebec out of us.
it makes me proud that you have kept good memories
Reactions: Washed-Up
Merci Mon homme…if the same frequency is coming from a new motor, I’d say the fan is not balanced properly
Does your distribution blower make the same noise, should I try a new one?
The way electric motors are designed is to operate at a specific voltage and frquency. 120/60 hz. When a potentiometer is used to lower the speed. It puts undue stress on the magnetic field in the windings and will make a noise similar to a bearing squealing. If it was not designed to work in the parameters the manufacturer required they will make noise. If it was not changed I would pull the motor and give it an oiling just to rule out that possibility. Now the question is has the motor been changed?
I got my Harmon XXV in Spring 2018. When I used it I would get noise. Thought it was Distribution Blower (Have new one sitting). When we removed it found 2 screws rubbing on frame of blower. Could not figure it out without removing blower. It's tons quieter now.
  • [Hearth.com] Harman p68 ringing noise
I'm not an engineer or anything. So what does that mean the fan is not balanced properly?
If there is dust build up on some of the fan blades it may cause some noise as the weight will distributed unevenly.
It could be a bad motor, when they installed mine and fired it up it had a little noise, the guy said it shouldn't sound like that and said he would bring a new motor for it. I was up by is shop and picked one up and swapped it out and have not had an issue since. Combustion motors I am on my 4th one I believe in 12.5 years.
Hello,
Mine does the same thing,and the blower and control board were replaced no help. Did you figure it out?
This has been driving us nuts for years. I'm thinking of seeing if I can clean the blower switch
I have been searching for an answer,or someone else with this same issue, with no help! Ive even contacted two different dealers and talked to two different service men, no idea. Motor, and control board replaced years ago, still making the ringing noise. Please someone help!
would cleaning the fan switch with contact cleaner help, as like this gentleman, the sound will come and go on its own depending on the speed the fan is running, or, if I move the switch up or down it will stop, or start. Thank you all in advance.
Cleaning of an electrical switch will do nothing. A drop or two of anderol /3in1 electric motor oil on the bearings, motor shaft bearings should be done every year.
My Harmon XXV had couple of screws impacting the Blower. Would make strange noises. I ordered new blower and saw this when we went to swap it out. Been running without annoying buzz and strange noise since 2018. We went ahead and put High Temp silicon on anything that would have metal to metal to quiet it down too. Only way to figure it out was pull it out of unit
Reactions: freebird77 and ARC
Try tightening the fasteners, lubricating the axle, checking the blade balance, and inspecting the bearings for play or damage.
Reactions: ARC
Not a bearing sound. Comes and goes with fan speed
The fan has bearing also! They are brass sintered bearings (under a microscope they look like a sponge) thats to hold lubrication.
Fixed it,finally. I put a screwdriver between the squirrel cage housing,and the housing for the windings,etc.
Just lightly wedged it . There,noise gone! I wedged a plastic spacer between the two. I couldn't be happier!!!
Reactions: Ssyko and Washed-Up
Glad it was an easy fix! Stay warm 😎
