Hello, I have had my Harman PC45 for several years now and have had a very good experience with it up until now. This past season it started to behave abnormally. I have the stove set on full auto and I have the external temperature wire. When the stove starts up it will run the auger, blowers, and igniter and then appear to stop momentarily and then turn everything back on again and then stop and start erratically. This erratic behavior continues after the stove ignites the pellets. The blower fan will speed up and slow down and the stove may somewhat operate for a while and then it seems to shutdown as normal.
So after googling and searching websites I completed the following steps.
I have cleaned the stove thoroughly cleaning everything that I can clean. I cleaned the interior, the exhaust fan, the stove pipe, and removed and cleaned the ESP. After cleaning the stove thoroughly I fired the stove back up and things appeared to be fine but after a few cycles the problem reappeared.
After the problem reappeared I replaced the ESP with a new one. I also removed the control board from the side of the stove and made sure that all connections and plugs on the control board were what to appeared to me to have been seated properly. I once again fired up the stove and the problem appeared to have been resolved but after 1 or 2 cycles the erratic behavior continued.
From my understanding the control board is one of the more expensive parts to replace but I want to rule it out before spending close to $300 for the replacement board. I'm hoping that someone on here can help me to troubleshoot the issue properly to rule out other inexpensive components that may be causing the issue and replace or troubleshoot those first before replacing the control board.
Any help will be greatly appreciated.
