I have a Harman PC45 that is in a space that was converted from a garage to living area. I am setting this space up to be a billiard room. It is not good for a pool table to see below freezing temps and high humidity Basically I would like to heat this at a minimum temp when it is not used to control humidity and keep at at a minimum temp using a minimum amount of pellets. Comfort is not my goal just higher than outside temp. I have been playing around with stove temp mode and keeping the feed rate turned down. I have been using it on manual as the igniter has burned out AGAIN (air pump work fine). Doing some reading here it looks like on manual and in stove temp mode set low the stove just keeps a maintenance flame and the blower won't come on. Maybe these stoves are really meant to run on room temp only? Any thoughts on settings for this situation.
