Harman Pellet Stove 3 blinks on Status Light see video!
Don2222
9,273
Salem NH
Hello
Status light on 8 year old Harman P61a blinks 3 short blinks when turning the stove on to stove temperature mode.
See video on youtube
Harman 3 Blinks on Status Light
Replacing the black ESP probe resolved the problem. See pic below
Has anyone fixed this error by doing something else? ? ?
Click pic to Enlarge
  • [Hearth.com] Harman Pellet Stove 3 blinks on Status Light see video!
Right from the Harman Manual:
3 Blinks: Indicates that the ESP (Exhaust Sensing Probe) has failed, has a broken connection,
or has gone out of range too many times. This requires a manual reset*
I would add: or a replacement.
They appear to be the only fixes.
I would add you might want to check to make sure there isn't an excessive amount of ash on the sensor. I read that cleaning this area and then resetting the stove might work.
Thanks for your comments, these are great answers!
The probe was really dirty, but since the stove is 8 years young (not old for a Harman!)
we just replaced it.
All mine takes is a yearly ESP cleaning. I did have a persistent three-blink problem earlier on and found that eliminating the surge protector cured it. No matter what flavor protector I tried it caused that problem.
Hello
After I installed the new room probe, I installed this surge protector which is one of the very best
Just google the following:
(broken link removed to http://www.eastcoasthearth.com/products/tripp-lite-ultrablok-isobar-surge-protector-suppressor-2-outlets-direct-plug-in-1410-joules)
This will also check if you have any polarity reversal or grounding problems so you can call in an electrician!
We would not run our stoves without it!
I've run my stove for years on house current and genny with no surge protector and no problems but I'll give it a shot. Thanks for the tip! :)
Harman is very specific about which surge protectors will work with their stoves. I don't know if you used something else, but the APC they listed is on my stove now without any issues.
Reactions: F4jock
Don't remember seeing these Harman recommendations but . . . .
I assume this is mainly for board protection and, although I've had zero problems running without one I ordered one as above to try.
Page 28 (Addendum C. Loss off Power - Minimizing smoke during loss).
Uninterruptible Power Supply (UPS) UPS battery back-ups are available online or at computer and
office equipment stores. Your Harman® appliance with Rev E or later software available beginning in
November 2010 may be plugged directly into a Harman® approved UPS:
• The APC (American Power Conversion) model #BE750G and the TrippLite model
INTERNET750U are tested and approved. Other brands or models may not be compatible.
When power is lost, a fully charged UPS will power a safe, combustion blower only shut-down. Your
appliance will pulse the blower every few seconds to clear exhaust until the fire is out. NOTE: The UPS
provides safe shut-down only. It is not intended for continued operation
Not in my manual. As well, I have an auto-start genny so UPS not needed. We were talking surge protector.
Ahh, my apologies, I got confused. I always get UPSs that act as the surge protector and wasn't thinking other people don't - or at least only use surge protectors
NP. :) IMO standard UPS is not desirable as it will only insure a safe shutdown, not operation. If I didn't have the Onan I'd design my own to allow running for a day or so. Easily enough done but when the power goes out around here it goes for as much as eight days. Living in the country as we do that would mean no heat, water or toilet facilities not to mention AC in the summer, thus the big-ass genny.
