Hi all,
I have been wrestling with an old Harman XXV (2004). It seems to be burning rich, leaving soot on the glass and heat exchanger. I have replaced the combustion blower motor and fan, new burn pot, new flame guide, new ESP sensor, new gaskets all around. It was installed with an OAK, which I recently disconnected because it seems to burn a bit cleaner with room air. No obstructions that I can see. Direct vented with only about 2 feet of pipe so easy to clean and see into.
I have tested the draft with a magnehelic and get good draft at the low and high draft setting in test mode. About 0.55 in low and 0.65 in high. During test mode the combustion blower light gets brighter when it is on high but no matter how hot I burn the stove it never goes off the dim (low) setting. Does anyone know if the light means anything during operation? Could the board be bad and not engaging the high draft?
Any thoughts would be much appreciated.
Thanks
Thanks
