Rick if you can be there when he "fixes" the stove, watch him and see if it looks like a bandaid fix. I didn't like the stuffing fix behind the screwhead at all.
Rick-In-RI said:Harry
The latest, greatest fix as you had mentioned:
The infamous “radiator clamp fix” secures the shroud housing...hard to explain where it is, but, its fed above the exhaust port from the combustion fan side, out to the other side, and around, tightened, and it supposedly stops the buzzing is the exact fix that the rep at Harman spoke to me about on Friday.
So let's recap what we know at this point.
Fix #1 - Place gasket material or silicone between the distribution blower and the shroud.
FAILED!
Fix #2 - The screw holding to two sections of the shroud together need to be backed off.
Then place gasket material behind the screw and between the distribution blower
and the shroud. Another option was to use silicone in place of the gasket material
FAILED!
Fix #3 - Replace the distribution blower's motor. FAILED!
Fix # 4- Apply a 4 1/2 hose clamp--The Jury is out
I don't know about anyone else, but, as I have said several times, these are "Band-Aid" fixes
and I don't have much faith in any of them.
In any case, my dealer called (finally) and is supposed to come out this afternoon to apply fix # 4. Having said that, when I asked him what time he would be arriving, I got the "I have to check my schedule and let you know." Translation: I'm not going to show up at all
patfan said:I have the same problem were did they place the clamp?
