I have an older 25th anniversary XXV stove, going on 12 years old.
After a Chimney cleaning a few months ago the stove would not start. I gathered it was from the ash and such so I cleaned all the piping it it start up fine. Recently though my stove has been having a problem that unless I bypass the Differential Switch (Pressure switch) my stove wont start.
So I went and did the following
Combustion motor was failing so I replaced that with a pellethead replacement motor, it sounds much better now.
Differential Switch, mine was old and I test it by applying negative pressure to the tube and I could hit it "trip" and connect
Door gasket
Hopper Gasket
Tube from hopper to Differential Switch, though the ID of the one I got online looks a tad smaller
Cleaned all exhaust pipes
The Differential Switch seems easy to manually trip so it looks like it would connect the circuit to start ignition
I can feel air coming out of the exhaust pipe when I pulled the stove away from the wall (xxv stove pipe adapter)
I have not replaced the Hopper Muffler, looked ok and I could get air through it when I pulled it
Amazon product
I am a bit on a loss why the Differential Switch wont still connect?
Door gasket
Hopper Gasket
Amazon product
