Hi. I can't pull the esp probe out for the life of me. I used pliers without luck. I did remove the sheet metal screw and it's on there solid (the esp that is). I put the screw back in so I don't lose it but it was out when I tried to removed the esp. My stove starts fine but then has a lazy black topped flame (horrible soot on the glass within minutes). After 10 minutes the stove doesn't feed anymore and shuts down. I cleaned everything really good except the combustion blower (can't get that off either) and the flue. I want to remove the esp to clean the flue really good and to clean the esp. I suspect once i do that I'll be back in business. My stove was built in 2015 (red wires are connected to the esp as the pic shows, if that helps any). I suppose I could just use a flue brush and be careful but I really want to clean the esp too. Thanks, Chris
