I've been using my stove for a week or so and it's been working just great. This morning, I cranked it up a bit to take the chill off; pellets feed, the ignition led is on, but no fire.
About a month ago, I did a good cleaning of the stove - scrapped the inside, cleaned the burn pot, vacuumed out the igniter area, pulled the back off, removed fines from the feeder (almost not btw), vacuumed the fan (also looked great), pulled the T fitting off and did what I could in the exhaust stack (nobody has 3" brushes so that'll have to wait a bit), then buttoned it all up and did a test run.
I run auto, room temp mode. This will be our 2nd year using the stove so it is almost exactly 1 year old (I think we got it in Nov/Dec last year).
I'll be re-cleaning the inside once the family is up. I've looked in the manual, and didn't find anything for this problem. I'm assuming that a blown fuse kills the whole stove so since everything else is running, that's not the problem. If I'm wrong and the fuse can kill just the igniter, let me know where the durn thing lives and I'll check it out.
I've searched the forum and the closed I found was someone who had a similar problem, but in that case the igniter led did not come on.
Is there anything else I should try/test/do before I call the dealer?
If it turns out to be a bad igniter, is that a homeowner fixable thing or should I expect the dealer to handle it.
TIA for any tips or advice.
Doug
Update 1 - cleaning didn't fix the problem.
Update 2 - I found the thread with directions for replacing the igniter; doesn't seem too hard so I'll give it a go. (/https://www.hearth.com/talk/threads/35605/)
Update 3 - very glad it's not all that cold yet...
Doug
