Hi! I am the happy owner of a second-hand Breckwell Blazer 1992 FS model. The other day the convection blower started clicking and then quit. After reading your troubleshooting pages I took it all apart and cleaned it out (there was ash in the fan and very dirty all over). Basically when activacted, the fan would turn a couple of times and then quit. I could hear it humming but not turning. Also I oiled the fan, although since the x boyfriend left several years ago I admit that I didn't know to do this so it hadn't been done for a while.
I took the motor out and cut the end off of a 125 volt cord, attacked the two wires of the cord to the two wires of the motor. It would hum and get hot. The shaft wouldn't turn, in fact it locked up and had no play when plugged in, just like when it was mounted in the stove. My current tester showed that a current was going through one wire, and going through the ground wire, but no current in the second wire (both are black). (The acutal motor is 115 volts)
I went to the Bob Vila site on how to test an appliance motor and followed his instructions. The multimeter did show a reading that indicated that the motor should be working (around 2 OHMS).
I noticed that the exbf did jump one of the thermo swithes, I'm guessing so that the fan would always be running. I reconnected this and it still didn't help.
I am going to call a repair person to come out to fix and service it (probably overdue). I just wanted to know if ya'll think I will need a new motor, as they are pretty expensive, and I like to know as much as I can so as not to be taken advantage of....
If anyone has any time and advice on a cold Thanksgiving day, I would greatly appreciate it!
I am glad I just rewired this old house (myself) so I can temporarily run a space heater and electric blanket.....
Thanks again! Kelly
Thanks again! Kelly
