Hello.   After many seasons of use (5+), when we go to turn on the fire place either through remote control or toggling switch to ON position on control box, the DEXEN module  593-592 attempts to light the pilot.  I  see the following occur:
1. The arc for 1-2 sec
2. Pilot flame comes on for approx ~2-3 seconds (pilot flame is strong and blue so I dont suspect a pilot line clog or dirty orfice)
3. Then everything abruptly stops. No arc as well is seen at this point.
I can get the pilot to stay on and main burner to ignite if I toggle the switch on remote box from REMOTE -> ON 10x-15x times. Basically if I attempt to turn off / on the switch repeatedly. On the 12-15th attempt, pilot stays on and burner lights. Main burner remains on for hours on end until I manually move switch to REMOTE position.
Could the issue be the Dixon module for some reason shorting out on during the attempts and then no longer sends the mvolts to pilot section of gas value causing plugger to close thus stopping gas to pilot line ? This in turn stops the entire lighting sequence in its path.
Troubleshooting:
1. Ohms at Pilot section on Valve - 38 Ohms
2. Ohms at Burner section on Valve - 58 Ohms
3. I clearly see ARC at the "I" pin on the DEXEN module when I remove connector and attempt to move it close to the pin. The ARC isnt that strong though.
I am unable to measure the mvolts at the pilot section of gas valve. It seems the DEXEN module on its way out however will function one out of many attempts. I have ordered a new module and keeping my fingers crossed. Thoughts anyone ? See video I have attached for how my pilot is acting.
Troubleshooting:
