Wall switch will not light the heat and glow after 10 seconds of being off
xpert66
3
Central New Jersey
Hi new member here. Looks like a great resource. I have the
Heat n Glo model SL-750TR-IPI-E fireplace and having an issue with it. I have a wall switch that controls the fireplace and do not use the remote. Currently there's no batteries in the remote but I need to toggle the remote module off then back on and the wall switch will work. I can turn off the fireplace and turn it back on several times and it works fine. Once I turn it off and wait 10 seconds or more the switch will not light the fireplace. If I leave the switch on and toggle the remote module off then back on, it lights. Again the wall switch will work but only within 10 seconds. After 10 seconds it will not relight again unless I retoggle the remote switch module off then to the on position. I replaced the Dexen wiring module and also the wall switch but the problem still exists. My next step is to replace the remote module but not sure that would work. Any suggestions I would greatly appreciate it. Thanks in advance.
begreen
Mooderator
Staff member
Nov 18, 2005
102,443
South Puget Sound, WA
Could the issue be with the wall switch itself?
Tjune54
31
Sulphur, La
That unit has IPI control and can't be used with a wall switch on the 120v circuit. It is to be cycled with the remote as the ignition unit will lock out after a power interruption.
Reactions: Lennox65
xpert66
3
Central New Jersey
Yes thank you. I kind of figured it out that that's the way it needs to be done. Using the remote works fine. Thank you
