Hello!
I am in the process of designing/building a hearth for my Jotul F 100 stove.
We removed an old wood burning insert and we will be venting the new Jotul out that same wall using a through-the-wall thimble (DuraPlus kit).
The F 100 has a rear heat shield, and it looks like there is also the same/similar metal shield installed on the bottom. Manufacturer clearances look pretty good.
My question pertains to building the hearth. The cabin is small (460 sq.ft.) and we don't want to build a stone fortress if the F 100's close clearances allow for a lesser design. I originally liked the online Jotul product shots that showed minimal installs with stoves sitting on clear glass sheets/slabs over wood flooring. Also some thin countertop-ish looking slabs on top of wood flooring... look like Silestone, granite, or slate? Some walls were simply finished sheetrock behind the stoves. No stone/tile coverings.
Are these type of minimal installs possible with this F 100 stove, given the clearances? Staged product shots? Obviously I will maintain all manufacturer clearances. The stoves in these product shots do look like they are too close to the wall if that is just sheetrock.
Here are some pics of the product shots I am referring to. Also including a pic my wall where the stove will be installed with the platform I started designing, that was to be covered in Durock and porcelain tile. Just considering my options before I proceed with the elevated porcelain plan. Appreciate any advice! Thank you!
