Can someone give me the lowdown on clearances required to install a hearthstone heritage. In particular, I am interested in the clearances from the stove sides to the wooden mantel, and from the stop top to the mantel above. It seems that depending on the thickness of the wood, the clearances vary, but that doesn't make any sense to me. The stove is installed on a proper pad (already), into a fireplace and connect to a SS liner, but I have put off rebuilding the mantel until I could understand the clearance requirements better....
It seems to be implying that the side pieces of the mantel can be as close as 8" away from the side of the mantel, but the mantel shelf must be 25 inches from the top, and that the distance from the top of the stove to *any* wood is 21...am I reading that correctly? The 8" seems very reasonable, the 25" to the mantel shelf also seems reasonable, and doable without a funny looking mantel, but 21" to the first piece of wood above the stove? That is going to make for a very high mantel...am I not interpreting this correctly?
EDIT: If the stove is not directly underneath the trip above the stove, i.e. the 1" wooden trim, but is instead 5" forward of that trim, does it make a difference? In other words, the only wood *above* the stove, is the mantel shelf, the other wood is "above" the stove, but back 4-5" inches
