Long time Lurker, first time poster. I have a hearthstone Manchester that was installed in February (2022). It is the 8362 model.
The stove runs 6" double walled excel pipe up 12' to my ceiling, joining into class A chimney pipe though a very tall attic and out the roof (straight up). I think the total length is probably around 30'.
The House itself is a 110 year old half insulated farm house so it draws very very well. I am burning 3 year old split post oak that is around 15 percent.
Really happy with the stove and the heat output but concerned over the stove top temps that happen during the secondary burn. This thing really throws the flames out the top, even when my primary air is shut down all the way (I run 95% of the time this way because of this concern). It was only around 44 degrees this morning and with a full load my IR gun is reading a few degrees below 700 and it is not uncommon for the stove to see this temp every other load even when the air is shut all the way. The secondary's are really Jetting out like a torch and I can hear it roaring when standing in front of the stove.
It only happens for the first 1.5" hours or so until the wood is done off gassing. It will then settle in at around 400 for a few hours before tailing off.
Since this stove has a jacket around the top its hard to get a good reading. Ive been shooting through the top holes and it seems hottest right above the 2 cats i think. I know cast Iron isnt rated to the same temp limits as steel and the manual is no help.
I engage the cat lever as soon as it reaches the active zone and have also tried shutting down the primary air prematurely to try and get ahead of this potential overheating problem. I almost always reach the "too hot zone" of the cat temp probe" which is also concerning.
Maybe I have too much draft and a damper should be installed but my dealer is leaning really hard against this stating that these new EPA stoves shut down pretty tight and they very rarely ever have to install one on a stove like this.
Am I worrying too much or over analyzing this thing?
Any suggestions or comments would be very much appreciated. I have run through around half a cord of wood so far. See below pics for reference
 ![[Hearth.com] Hearthstone Manchester running Too Hot from secondary's? [Hearth.com] Hearthstone Manchester running Too Hot from secondary's?](https://www.hearth.com/talk/data/attachments/305/305823-090077ebd6ff832afea8c517f89e92c6.jpg?hash=tRC88FBGhW)
	![[Hearth.com] Hearthstone Manchester running Too Hot from secondary's? [Hearth.com] Hearthstone Manchester running Too Hot from secondary's?](https://www.hearth.com/talk/data/attachments/306/306828-390c3659bda5dc296b8980a639d603bc.jpg?hash=zSaRayBpyH)
![[Hearth.com] Hearthstone Manchester running Too Hot from secondary's? [Hearth.com] Hearthstone Manchester running Too Hot from secondary's?](https://www.hearth.com/talk/data/attachments/306/306829-cbe67372092221101accd4c5fc1527e7.jpg?hash=MqAItJARu3)
![[Hearth.com] Hearthstone Manchester running Too Hot from secondary's? [Hearth.com] Hearthstone Manchester running Too Hot from secondary's?](https://www.hearth.com/talk/data/attachments/306/306830-b519e74776c7672ad12a93034f481d44.jpg?hash=ajOe0etqAe)
![[Hearth.com] Hearthstone Manchester running Too Hot from secondary's? [Hearth.com] Hearthstone Manchester running Too Hot from secondary's?](https://www.hearth.com/talk/data/attachments/306/306831-d674def4659f4c23ed95297fe32a3ba1.jpg?hash=09D7qZXtXO)
![[Hearth.com] Hearthstone Manchester running Too Hot from secondary's? [Hearth.com] Hearthstone Manchester running Too Hot from secondary's?](https://www.hearth.com/talk/data/attachments/306/306832-7e3005229856952e96380eb92d984e8b.jpg?hash=4K16X5Q4-k)
![[Hearth.com] Hearthstone Manchester running Too Hot from secondary's? [Hearth.com] Hearthstone Manchester running Too Hot from secondary's?](https://www.hearth.com/talk/data/attachments/306/306833-271649e7639dbc4ba9b4efc9b199db25.jpg?hash=bAK1iVIBtf)
![[Hearth.com] Hearthstone Manchester running Too Hot from secondary's? [Hearth.com] Hearthstone Manchester running Too Hot from secondary's?](https://www.hearth.com/talk/data/attachments/306/306834-dfaf6571f0a65f25e64c57594fb2b9a1.jpg?hash=Rvoo5oSoWk)
![[Hearth.com] Hearthstone Manchester running Too Hot from secondary's? [Hearth.com] Hearthstone Manchester running Too Hot from secondary's?](https://www.hearth.com/talk/data/attachments/323/323347-6dea6cf803a738f50b9dc5cad6d7ee8d.jpg?hash=Rd173U4-7o)
![[Hearth.com] Hearthstone Manchester running Too Hot from secondary's? [Hearth.com] Hearthstone Manchester running Too Hot from secondary's?](https://www.hearth.com/talk/data/attachments/323/323348-d866106a72a88fcf6a75e04b560d921d.jpg?hash=ANeXYJ2Gmc)
![[Hearth.com] Hearthstone Manchester running Too Hot from secondary's? [Hearth.com] Hearthstone Manchester running Too Hot from secondary's?](https://www.hearth.com/talk/data/attachments/323/323349-65c591cf1493c7aee0348ff5ea843431.jpg?hash=zJP4ASi_e3)
![[Hearth.com] Hearthstone Manchester running Too Hot from secondary's? [Hearth.com] Hearthstone Manchester running Too Hot from secondary's?](https://www.hearth.com/talk/data/attachments/323/323350-6ddb6995995a329007d1f21691aebe4f.jpg?hash=7YydKEPF_6)
