In a different thread I read that the HC will turn on the blower based on the plenum temperature. Is that correct? I believe it monitor temps in the firebox, the baffles? And the plenum.
Here is my confusion... Scenario: Heat is unavailable based on the led and the thermostat is calling for heat. When I have a few coals left and do a reload the blower kicks on almost immediately. At this point the plenum is not even warm. This doesn't seem right.
If I let it continue to run the plenum struggles for a while to get up to temp (which results in lower supply temps) and the blower will run much longer. To keep this from happening I have to turn off the thermostat until the HC gets hot (I usually wait until it kicks on the blower to cool itself off the first time).
It seems like my blower is kicking on way too early. How can I determine if there is something wrong?
I appreciate any insight to this!
Lee
Lee
