I've discussed here before the two-stage heat pump I installed a year-plus ago; it also has 8kW heat strips.
This is the first winter (only the system's second winter) where it's been cold enough to require activating the heat strips much (especially since I heat mostly with wood), so I've just now noticed that when the heat strips come on, that the compressor is not running. I've confirmed that the thermostat is energizing the G, W, and Y signals; it seems to me like the compressor should be running. What could be wrong and preventing this ?
Here is the wiring diagram:
It seems to me like the problem must be in the compressor. The Y signals go first to the air handler, but the same conductors go to the compressor; so it's unlikely the air handler is telling the compressor to shut off (it's possible it could be pulling the Y signals low, but that seems unlikely). So I'm thinking that when the compressor sees W energized, it shuts off even though the Y signals are energized. (Of course the compressor needs to be connected to W, because it energizes W when it goes int defrost mode so that there's some heat).
I guess I could disconnect W from the compressor and see what happens.
The whole thing is a little harder to investigate because it's hard to reproduce; I never quite know when the thermostat is going to decide it's time to turn on the heat strips, so I can't observe the codes that the air handler and compressor are flashing on their little LED displays (worse, you have to take the cover off the compressor's wiring area to see its LEDs, in fact I'm thinking about installing a little window in the cover). I'm wondering if I could just force heat-strip mode by shorting R to W, since after all, that's exactly what the thermostat does when it wants to call for the heat strips. Could it damage the thermostat ? I think not, because the compressor can also energize W (when it goes into defrost mode, I believe these are what a EE would call "wired-or" signals). Or, I could change the settings on the thermostat to tell it their aren't any heat strips, but to be safest I guess I should disconnect W from the thermostat.
Anyhow, mainly wondering if anyone has thoughts about why this is happening, and also about my hack to try to reproduce the behavior.
