Heat Recovery fans causing home fires , recalls
DriftWood
718
Bluewater Area, Great Lakes
Heat Recovery
If your house was built anytime after the late 90's chances are you have a heat recovery ventilation system that exchanges outside and inside air. But there's been a problem with the device that does that...it could cause your house to go up in flames.
The motors are starting house fires. Get the model and serial number off the unit and call the manufacture about recalls. Also the motors burn out with age 6 to 7 years. Call the manufacture.
Listen to the Item
Runs 5:08
(broken link removed)
Monday January 07 , 2008 Heat Recovery
http://www.cbc.ca/ontariotoday/story_archive.html
If these links are not opening.
Turn on your computer speakers.
Try copying the link and past it in the address window, press enter.
Update your real player. http://www.real.com/
Somewhere Elk is smiling
Cant get the links to work,
I have an ERV,
can You give us the low down ?
Thanks,
Nick
I have an ERV,
Thanks,
Nick
Try copying the links and past it in the address window press enter.
