Hello stranger,
I was hoping I could get some advice from you.
We have a 1930's house, poor insulation. ~1000sqft
Our goal is to get a (broken link removed), use the rear vent to go back and up the chimney. The Defiant looks like it requires a minimum 26" height for the flue to clear, 28" tall in all.
We have a (broken link removed) with holes and the like and an entrance that is 25" tall.
In a perfect world the end result is a faceless Inglenook-y look.
My questions for ya:
Can we remove the whole first layer veneer/face from top to bottom?
-It would make removal easier and it would increase the height of the opening for the rear flue vent to actually fit. The brick facing does not seem to extend into the roof.
How is terra cotta supported in a chimney? Will it collapse if I remove the heatform?
If I remove the heatform should firebrick/masonry be added even if the stove is properly distanced?
We are already insured for an insert. If all work is to code and passes a Tier II inspection will it likely be a non-issue?
I appreciate any help and advice.
