We bought a house a few months ago with an old Heatilator Mark 123 (model #3138EP). We had a sweep out to do a level 2 inspection but before he even got that far, he said the gap in the venting is a problem they often see with the firebox settling, and it was unsafe to use.
Priorities:
Using fire for ambiance
Want to burn wood
Heat is a nice bonus but not required. We have a couch just a few feet away so too much heat would be bad the way we have the room set up.
Efficiency isn't really a priority (but again, a nice bonus) and there are no restrictions on fireplace types where I live (i.e., don't need EPA)
We went to a big local fireplace chain to ask about options - they suggested a new ZC fireplace (Heat and Glo Royal Hearth 42). They wanted to come in through the exterior wall to redo the chimney. Didn't like the idea of wood inserts and said they don't do them entirely. The second place I went to was pretty strongly in favor of an insert. They suggested the Fireplace Xtordinair Small Flush Hybrid-Fyre. I asked the tech from the 2nd place if it was an issue installing it into the ZC fireplace with the gap the sweep didn't like, and he didn't think it was an issue. I could see the answer going either way, because on one hand, it's a compromised installation and presumably not what the insert was tested with, but on the other hand, if they're putting new exhaust pipe up the chimney, maybe it doesn't matter.
I called the first place back to follow up, and they insisted the inserts were just too heavy. The fireplace is elevated (on a 18" hearth, and the firebox is ~3" above the hearth) and on an exterior wall. The insert in question weighs 265lbs per the manufacturer. Both quotes are about the same price - I want this to be done safely, but also as non-disruptively as possible. Given that the insert is UL listed and rated for installation into a ZC fireplace, I'm a little confused why two stores differ on this.
What would you do in this situation?
Images:
Priorities:
Want to burn wood
Images:
