Heatilator Mark 123
Ablaze911
5
New Jersey
I have a Heatilator 123 in my home installed in 1973 when the home was built. Doing some renovation in my garage which has exposed the rear of the unit.
[Hearth.com] Heatilator Mark 123
It is currently wood burning, but I would like to do a gas log insert. Do I have any option that would allow me to keep my TV? I know it's a stupid place to put a flat screen, but I'm hoping to get away with it. I don't care about the heat aspect, I really just want the look/ambiance. The insulation was good old Corning pink fiberglass. Recommendations for suitable insulation followed by 5/8" gypsum? Flame away, guys...
  • [Hearth.com] Heatilator Mark 123
I would not make that assumption. The vents should not be blocked. Maybe just run a fire burning DVD on the television instead.
What do you think about relocating the vents to the side?
Ok, I'm an ass. Re-read manual and now understand that the vents allow air to regulate temperature of the unit...
Should be ok as long as done per manual instructions.
Not to be pedantic.. But I guess I don't understand why I can't just eliminate the recirculation aspect of the Heatilator. It seems like I could use the firebox and chimney as a normal fireplace and then install an insert accordingly.
LCD tvs are cheap. Maybe put a 2nd screen in the fireplace and run a good fireplace DVD when ambience is desired.
Feeling a bit facetious this morning?
