Greetings Hearth and huge thank you for the wealth of info and help shared here!
I have what appears to be an early version of Heatilator (house built in 1940s and guessing heatlilator is original?). Guessing it needs to be fully removed given the rust and deterioration.
Also bought a very nice used Quadrafire 4100 with 12'+ of 6" double wall insulation and a 5' section of 6" stainless flex ducting that we are (were) hoping to install - plenty for our chimney height.
I tried cutting a center section of the heatilator out (removed damper, etc.) in hopes it would allow for the 6" pipe to route past the heatilator without having to remove the whole thing, only to find that we have what is likely a 8x18 (o.d.) terra cotta liner past the top of the heatilator to the top of the chimney about 10' +/-.
So the (noob) questions are;
- Can the 6" round be run into / through the terra cotta (doesn't seem like it will fit, aside from not being safe?)
- Or, can we use the existing terra cotta as is (without a liner)?
- Better / best to remove the heatilator with as rusted / deteriorated as it is?
Photos attached - can provide more photos or info if needed.
Thank you!
![[Hearth.com] Heatilator removal, terra cotta liner and insert installation questions [Hearth.com] Heatilator removal, terra cotta liner and insert installation questions](https://www.hearth.com/talk/data/attachments/300/300742-e7101c18a90c1695e17b034b3107b2bb.jpg?hash=SdGFtqPya9)
Thank you!
![[Hearth.com] Heatilator removal, terra cotta liner and insert installation questions [Hearth.com] Heatilator removal, terra cotta liner and insert installation questions](https://www.hearth.com/talk/data/attachments/300/300737-6c7182ebe07e49b0126bba68b6d01dfb.jpg?hash=A0KfCyoAa3)
![[Hearth.com] Heatilator removal, terra cotta liner and insert installation questions [Hearth.com] Heatilator removal, terra cotta liner and insert installation questions](https://www.hearth.com/talk/data/attachments/300/300738-bd090ee619d3e0df3ede5f856d672a14.jpg?hash=g313B0LIEb)
![[Hearth.com] Heatilator removal, terra cotta liner and insert installation questions [Hearth.com] Heatilator removal, terra cotta liner and insert installation questions](https://www.hearth.com/talk/data/attachments/300/300739-704ee72067cbd0c1791829bc36f15a0d.jpg?hash=ETkfA03ItZ)
![[Hearth.com] Heatilator removal, terra cotta liner and insert installation questions [Hearth.com] Heatilator removal, terra cotta liner and insert installation questions](https://www.hearth.com/talk/data/attachments/300/300740-53a4548c1bd4881a95a9829266badb45.jpg?hash=_0QHUrcxz5)
![[Hearth.com] Heatilator removal, terra cotta liner and insert installation questions [Hearth.com] Heatilator removal, terra cotta liner and insert installation questions](https://www.hearth.com/talk/data/attachments/300/300741-2d3f624a7bffff6e2ee7dde0066b632e.jpg?hash=mlMzVvuHDL)
